(SOLVED) Control solenoid valve with Arduino or with circuit
ericgibbs
Joined Jan 29, 2010
21,537
hi,
The diode is just to clamp the back EMF created from switching the relay inductive coil Off.
A general purpose diode with a rating greater than 100v and say 100mA will be fine.
E
Sourc3
Joined Dec 2, 2021
81
hi,
E
Ahh nice, I thought that for my circuit, maybe I can get some diode from some board, I have thousand here.
Sourc3
Joined Dec 2, 2021
81
hi,
E
I will SIM the circuit first, I dont understand some points, I will post the result in a moment.
Sourc3
Joined Dec 2, 2021
81
hi,
E
Ok, so u need to have the relay in Normally Open mode, so the difference between 20ohm and 60ohm(steam nitrogen) is closed and when there is no nitrogen (60 ohm), its should be activated.
ericgibbs
Joined Jan 29, 2010
21,537
hi Sourc,
Most relays have change over contacts,
ie: one normally closed and the other normally open.
Change over when energized.
Let me know the result of your simulation.
E
ericgibbs
Joined Jan 29, 2010
21,537
Hi S,
The circuit simulation I posted works as you asked.+40C relay ON, less than +40C relay OFF.
I have decreased the hysteresis to about 1C.
Why do you say it didn't work as expected.??
also, why was the 115R changed to 60R.??
E
Sourc3
Joined Dec 2, 2021
81
Hi S,
E
Aaaah I understand now the confusion, when I said 40, I refer to Ohm not to Celsius.
I mean, need ON with 40-60 ohm or superior, and OFF with less than that. That is translated to ON in -50C to -100C and OFF with less than -100C. That why the reference resistor should be around 60ohm. (Steam/vapors nitrogen are -90C aprox).
ericgibbs
Joined Jan 29, 2010
21,537
hi @Sourc3
So to simplify, when using a PT100
Relay Off when lower temperature than -100C
and
Relay On when temperature higher than -100C
Can you confirm this.?
E
ericgibbs
Joined Jan 29, 2010
21,537
hi Sourc
Check this simulation for -100C change over.
Do you follow it OK.?
I would recommend 0.1% tolerance resistors and R5 be 100 Ohm 20 turn trim pot, for calibrating.
E
