I'd like to understand the functions of solenoid control in a DC environment. Right now I have pulsed solenoid control, it's square wave, 0 to 10vDC and it cycles at about 312hz.
I believe the way the solenoid is controlled is duration of each cycle of high vs low.
I am wondering that if the analog value was calculated from the square wave value, would the solenoid function the same way sans a possible heat issue?
Theoretically, if the pulsed square wave calculated average for a certain position was 6.2v, could I send 6.2vDC analog and see the same movement?
Theoretically could I introduce analog voltage from the same power supply to the square wave signal and bias the square wave signal, would I therefore cause the same overall effect as if I were to increase the duration of each wave? Thanks for reading!
