Motion detector solenoid lol
Erock12
Joined Dec 26, 2023
20
Hey! Super beginner here, I’m looking to design a system, that a pir controls 2 push solenoids. im assuming I need a controller or a contactor, for once motion is detected I need solenoid 1 to push out, then once motion is no longer being detected I need solenoid 2 to push out, I’m a electrician so I have a basic concept to circuitry, but I just don’t know the fine print of getting a pir to control 2 solenoids individually, with or without a controller
ronsimpson
Joined Oct 7, 2019
4,888
Do you have a picture or part number on the solenoid you want to use? AC or DC? What voltage?
Does the solenoid go out when power is applied and then come back in when there is no power?
What kind of signal comes from the motion detector?
Start out with no motion, both solenoids are in.
Morion detected, 1=out, 2=in.
No motion, 1=?, 2=out. What condition should solenoid 1 be in?
How do you want to reset back to 1=in, 2=in?
Erock12
Joined Dec 26, 2023
20
So I want both solenoid to be in with no motion, once motion I want solenoid 1 to go out then back in, then with motion solenoid 2 to go out then back in.
or if it makes it easier, with motion 1 out, then no motion 1 goes in, 2 goes out and vice versa. I planned on using a 5-6v battery.
further research I may have to use a 2 channel relay with the pir
GetDeviceInfo
Joined Jun 7, 2009
2,286
Have the PIR drive a SPDT relay of sufficient rating to drive the solenoids. One solenoid on NC, other on NO, with common connected to whatever voltage source the solenoids require.
Erock12
Joined Dec 26, 2023
20
the only issue with this that I see, is the solenoids are only able to be powered for 1sec. So from what I am seeing, both of them needed me to be closed, then once power is supplied, it needs to solenoid 1 needs to push out, then back in. Then once motion is gone, solenoid 2 gets energized pushes out then back in
Erock12
Joined Dec 26, 2023
20
that’s what I’m going to need it to do, I’m still planning this project so I haven’t benchtested anything, but I assume, with the no/nc relay, once motion is detected the voltage will stay on that solenoid for extended periods of time with this setup.
But if I added a microcontroller I assume I’d be able to program that controller to send voltage to push solenoid out, then in.
then once motion is gone, send solenoid 2 out to shut it off, then solenoid solenoid return in.
BobTPH
Joined Jun 5, 2013
11,678
If you are experienced with microcontrollers, this is by far the easiest solution. It also has the advantage that you can adjust the behavior in firmware, should you decide the timing needs to be different. Even if you are not experienced, someone here should be able to get you going with Arduino and a relay shield.
Erock12
Joined Dec 26, 2023
20
Sweet, I’m going to look into buying the components today and get them, should I just keep posting it this or try to go to a arduino forum?
Ya’akov
Joined Jan 27, 2019
10,368
Welcome to AAC.
you can get the help you need here. It would also help to know what the solenoids are doing.
ronsimpson
Joined Oct 7, 2019
4,888
I am looking at the CD4538B IC which is a dual multivibrator. One half will make a 1 second pulse on every rising edge while the other half will make a 1 second pulse on the falling edge. (time is set by a resistor & capacitor) This IC will make the two signals you need from the motion detector. I don't have time to work on this today. It is a simple project for those that solder parts together.
Erock12
Joined Dec 26, 2023
20
I’d like to connect at some point via email or text to get more of your idea, I have a slight concept but it’ll be good to get a clear picture
MaxHeadRoom
Joined Jul 18, 2013
30,884
What are the solenoids operating, e.g. Nature of the load, I assume these are not pneumatic or hydraulic versions?, But moving some physical actuator?
Do you presently have the solenoids?
Erock12
Joined Dec 26, 2023
20
I do not have them currently, I’m getting a list and going to order today, they are 5v solenoids 0.5ma current. They will just be pressing a button
28,590
Will the solenoids possibly also have a switch to sense when they are extended? That could make the control scheme simpler, and are you going to want adjustable times for them to stay extended? What sort of output will the PIR sensor have? Will the whole system be battery powered so that minimum power consumption is a goal?
Erock12
Joined Dec 26, 2023
20
I didn’t have anything planned to sense when they are extended, I figured the controller will be able to send out the current whenever the motion is detected or not detected. Yes it will be battery detected, I planned a 9v battery for everything
MaxHeadRoom
Joined Jul 18, 2013
30,884
Do they require retention when activated or can they be momentary/maintained?
The former generally only requires one coil.
Have you calculated the force required?
Ya’akov
Joined Jan 27, 2019
10,368
The PP3 (9V battery) is a terrible power source, particularly for high current applications like solenoids. I encourage you to consider something else. Even 6 AA cells are much, much better than the 9V. But even better than that is a rechargeable option, like LiPo or other lithium based cells.
