Solar PWM Charging Mosfet Selection
sonar_abhi
Joined Mar 19, 2016
22
Hello Guys.
I am making a Solar Charge Controller with PWM. For PWM, I need to connect the MOSFET to the high side so as to control the current going into the battery from the panel.
If I connect an N channel MOSFET, that would need a charge pump to increase the gate voltage above the Vdd.
But if I use a P channel MOSFET, that would not be necessity, since I only need to turn off the gate supply for the MOSFET to conduct and vice versa.
Some of the examples on the net have used N channel with a charge pump and I really dont understand why they have not used a P channel MOSFET instead.
What would be a better selection in terms of efficiency and power dissipation.
Thanks
AS
DickCappels
Joined Aug 21, 2008
10,186
Your observation are valid. I would go with a P-channel MOSFET.
The N-Channel MOSFET in the circuit above can be replaced with a diode, but at slightly lower efficiency.
sonar_abhi
Joined Mar 19, 2016
22
Hi DC,
Thanks for the reply. Ideally, I would want the drop to be "0", but putting a N Mosfet instead of the diode, will again require a gate drive circuitry, won't it?
Also can you please share the buck converter calculations?
Regards,
AS
Lestraveled
Joined May 19, 2014
1,946
@DickCappels @sonar_abhi
Dick, I think Sonar is talking about a non-inductor based simple PWM charge controller, not a power converter.
Sonar, "Charge Controllers" may be cheap and easy to build but they are not efficient. Dick is talking about a power converter, which is very efficient compared to a charge controller.
What is your application?
