I have 6 solar panels that are only 2 years old and giving varied dc voltage output. I'm hoping its the bypass diodes. I cant see any other damage to the cells on the panels. (Note: these are rejected panels - no warranty)
There are (3) Junction Boxes. (Positive-out) (center-no lead) and (Negative-out). They are potted for IP67 waterproof and sealed to the panel back. I removed the potting in all 3 boxes to identify the diodes. A THY 2550 was in all 3. Each box is tied to 24 cells.
I can't find an exact match to that diode #.? I cant find the manufacturer for that diode logo.?
Can someone point me to a diode that would be comparable?
I'd really like to improve the Forward Voltage Drop quality of the diode if you have any suggestions?
Thanks in advance for any help!
Diodes I've found:
https://www.westfloridacomponents.c...ifier+Diode+Micro+Commercial+Components®.html
https://www.westfloridacomponents.com/mm5/graphics/R10/MBRB20100CT.pdf
Panel Info:
Diode in box
Diodes I've found:
Panel Info:
Diode in box
