Solar panel dusk to dawn help
Fuego1932
Joined May 11, 2025
I’m trying to find/build a small solar panel that will charge 8 AA batteries (12v) during daylight then at dusk the batteries would then power an LED light. The LED is an ember flicker type to simulate a candle flame. This is for an outdoor display but I need 12-20 units.
Ideally I would prefer to purchase something but I can assemble it if I know what to get. Everything I’ve seen is for lower voltage setups.
I could use a lower voltage setup but I haven’t found bright enough LEDs.
Any help/suggestions would be greatly appreciate.
BobTPH
Joined Jun 5, 2013
11,662
Individual LEDs operate at a max of under 4V. You can get any brightness you want from a low voltage, it is the current that you need to increase for higher brightness.
35,235
I would not use AA batteries. I would use a 12 V SLAB (sealed lead acid battery) instead. They are more robust and can take a lot of abuse. Small solar panels are readily available that will charge 12 V batteries.
