Hi, I bought 2 solar panels 100watt 20v with 5amp max at sticker (mono), I connected it in parallel.
It gave me (both) only 3.5 amp, and some time (after heating up) about 2 ampere, as I expected it should be more than 6 for both of it.
I measured it by millimeter with 10A (short circuit) directly for each panel, only about 1.5 amp for each
and I measured it both as short circuit too.
Is my panels are damaged, do I damaged it, my bad I have no warranty.
Is it kind of bad panels and the vendor cheated me?
Can Bypass diodes be broken and waste power?
do i need that bypass diodes with panel connected in parallel?
I read here in the forum and internet about solar panels and diodes but I am confused, what is my fault.
Thanks in advance.
Thanks in advance.
