I'm in the Arizona Dessert Approx: 300 clear days, 30 partly, 35 Overcast.
5 years ago It started to be just a backup off grid system.
Then I discovered Grid tie inverters, then I discovered how inept the power company was.
So, I Parted out the 2 new grid tie Inverters and went totally off grid.
The Programmable Logic Controller (PLC) watches the time, battery voltage and Intensity of the sun.
Then turns the loads on and off in sequence according to the amount of power coming from the panels.
I only use the Batteries to run the outside flood lights at night, thus not running the battery's up and down a lot.
The system is 5 years old now and the battery's are still in good shape. Wish i could say the same for the panels.
Approx system cost. It's about 20% low I'm still trying to justify Putting the system in. It's a hobby, there that helps.
("small print" don't do it for the money.)
Solar Panels 45 each 100W Rated / 40 Watts actual 10Hr/Day $100 ea $4,500
18 KW / Day = 540 / month Times 16Cents = $86.40 / Month
Solar 80 Regulators 5 each $100 ea $500
Inverters 7 each $140 ea $980
Batteries 6V RE220 AH Trogens 6 each $150 ea $900
Solar Wire #12 (Yes it's special) $200
PLC Logic Controller Keyence 1 each $ 250 $250
Battery Chargers 2 each $ 100 $200
Misc Parts $ 420 $420
My Labor $00.00 $ 000 $000
Total $7,780
Total Investment Pay off 7.5 Years at18KW per day at 16Cents / KW
Related but not included Cost (Medical falling off ladder) $500
psychotherapy (After Programing the PLC) $400
Total $7,780
