I have 11 modules of Sharp NA-E120G5 48vdc and i want an off-grid system (i.e day-light use only with no batteries).I either can put 5 modules in series to get 240vdc paralleled with 5 more modules in the same fashion 240vdc(by using 10 modules) (1250w) or 11 modules in parallel fashion (48vdc) (1375w).As i need 220vac to run my load that is a normal house load.
Which scheme is better?
Inverter should be of what type and how much minimum KWs should inverter be?
Do i need any other device than inverter? i.e controller,etc
Or any other suggestion?
Thanks.
Thanks.
