Best software for System Drawings and/or Assembly and/or Sub-Assembly "connections" ?
Fran3
Joined Mar 28, 2019
51
What is the best System Design and or Block Diagram software and/or Assembly and/or Sub-assembly inter-connection drawings?
May show something like...
  • Sub-Assembly A as a box with 3 connectors
  • Sub Assembly B as a box with 2 connectors
  • Sub Assembly C as a box with 1 connector
  • All Inside a "box" labeled Main Assembly
  • Which may have a power LED, power switch, AC power connector, etc
Another way to think about it is... for instance...
  • a PC showing a box for the mother board
  • a box for each daughter board
  • a box for the power supply
  • and the main case's front panel and rear panel
  • etc
Thanks for any help.
PS - I have used with InkScape and LibreCad but wanted to hear what you guys use.
LowQCab
Joined Nov 6, 2012
5,102
I don't like any of them .........
( at least the ones I've seen )
You can also use any decent Photo-Editing Program,
( not the cheezy kind that just "fixes "Red-Eye" and lets You Crop the Picture and adjust the Contrast ).
I use an old program called "Microsoft-Picture-It",
( difficult to find now, and even more difficult to get it working on a modern Box ).
An example of what You could learn to do with "Photo-Editing" Software ..........
You can make it as simple or detailed as You prefer.
Marley
Joined Apr 4, 2016
519
Have a look at diagrams.net (previously known as draw.io) it's the best replacement for Visio that I have found. You can use online or install an application.
Or kicad.
All Linux - Windows - and probably Mac.
MaxHeadRoom
Joined Jul 18, 2013
30,810
As far as i could see the OP did not mention schematic drawing, for which I use (free) Kicad.
It is not that suited to mechanical drawings however, as the OP mentioned his need was for a AutoCad style pgm.?
Fran3
Joined Mar 28, 2019
51
Kicad:
I've ended up using Kicad with various connector symbols for this project. Making it a little more detailed than a set of boxes interconnected with lines.
LibreCAD:
I experimented with using LibreCAD. I made my own connector parts library for it.
Their electronics library came with a warning about malware so I decided not to download it.
Down side to me was LibreCAD apparently doesn't let you "weld" a line to the side of a shape... like connecting a line to the side of a rectangle representing a sub-assembly connection. (Can't make a "T" connection as I understood it.)
I do like LibreCAD however.
However I do wonder how big their active userbase actually is?
Inkscape:
Inkscape is is a another alternative and a big favorite of mine. I use it often for a wide variety of things.
These are all open source choices. For very high level system diagrams I've seen people use Microsoft Power Point.
Google has a free alternative to this included with the Google Apps you get when you get a gmail account.
Thanks for all the suggestions folks!
