This was a gift I gave my parents some years ago. After my dad passed away in 2012 I got it back. After replacing the Rechargeable battery in 12' it has been out in the Center of my pond at my Cabin. Last time there I seen it wasn't working right and thought it only needed a LEd or 2 replaced. So Today while there I Detached the top and brought it home so I could give it some fresh paint and replace the LEDs. While only 2 where broke at the hat as I was removing them a couple of the others just snapped with very little pressure so had already planned to replace them all..
However thought I would mention that there was some heavy damage to this PCB with signs of water damage. Growing corrosion around most Voltage traces. After doing some minor cleaning I installed all the LEDS back into the PCB and it did work as it should have besides one LED. this was do to bad trace.. So I made a jumper to test that it was working as it should. However do to the damage of the rest of the PCB I took all the LEDS and Header pins out of the board only leaving the few SMD parts and the mound with hidden chip. The header pins connect to a different PCB with Solar controller and other items. that board is without damage.
Trying to clean this off without to much damage proved to be harder and the corrosion had eaten some other traces right up to the Hidden chip dome. I do have a 2032 for my Hakko FX-951 and have some small micro tips. My main issue is I don't know really how some of the tracks were laid. There is one on the right side of the hidden chip mound that looks like it may have been coupled with one trace that split into 2 others one going to the chip before a Resistor and one after the resistor.
Anyone have an idea what Chip may be under this mound so I can try and find a data sheet on it so I can repair this PCB? I know posting a picture of front and back of PCB would help much. However I thought maybe someone might see how this is laid out and may have dealt with a chip on this type of setup
I would be willing to design another PCB that I could use in this place if I needed to. I just don't know what type of chip would work with 6 LEDs on a 1.2v. I did hook up a PSU and gave this setup 1.5 to 1.8v to see what the current draw was and was no more then 40ma. Without the LED PCB plugged in the draw was 18ma. Over 2v the main PCB went into protection so it does have a Over voltage protection on the main PCB.
Because of where I have this Lighthouse placed on my Pond, I would like to try and design something that would be able to run off the Solar system and a 1.2v AA.
James
James
