solar led lights
beatsal
Joined Jan 21, 2018
425
I got a solar led light from Ali Express. These use a Li battery 3.7 V and 20 LEDs. Worked fine for 3 months but now stopped working.. Any ideas what to check for. Battery V checks OK.
LowQCab
Joined Nov 6, 2012
5,101
~90-days is actually an impressive run for such a device.
There are generally 2-solutions to your dilemma,
1) Buy another identical Light,
or,
2) Purchase top quality Components and build it yourself, ( probably ~40 to ~60 bucks ),
insuring that it is thoroughly weather-proofed in every way possible.
This will probably give You a ~2 to ~3-year life expectancy before failure.
Then build another one.
Solar Walk-way Lights are a gimmick,
but they can be had for soooo-cheap that people will buy them anyway.
And Grandma can install them, 'cause there's no Wires.
Electronic-Components don't like existing and operating in a hostile, wet, environment,
especially cheap-Electronics.
Tonyr1084
Joined Sep 24, 2015
9,744
Wife buys those cheap garden figurines that light up. They quit working frequently. I've found the switch to be the major problem in many cases. In other cases, after a few years, they stop working because the battery is cheap. I'm talking about those 1.2V batteries, I believe they are NMH (Nickel Metal Hydride). Not positive about that - but - - - .
schmitt trigger
Joined Jul 12, 2010
2,163
Yes, they are NiMh batteries.
Another common problem is that the solar cell’s internal joints open up.
The small control IC becomes defective.
As LowQ mentioned, these solar garden lights are designed to become E-waste in a single season.
