LED string lights with 18560 and 2 2.5w 5v solar panels
RichJacot
Joined Jul 23, 2019
I'd like to have a solar powered light string using the panel as on at duck off at dawn.
I have two 5v 2.5w solar panels in parallel.
One 18650 battery, 2500mAh.
I have a string of 12 LED lights 1 watt per bulb.
I'd like to use a TP4056 module with protection for charging.
I'm thinking of something similar to the attached Capture.PNG.
I've done some simpler stuff but I'm not a transistor guy. I don't think the 9013 in the schematic will handle the 12 1w bulbs.
Any recommendation on the design and if the 9013 will work or another that will?
TIA
