A couple of days ago I replaced my 12V/0,7A power supply to a 12V/2,1A power supply that I use for a couple of purposes. Everything looked okay until I found that my 1-wire network is completely down which I know happens as a result of noise. (The network is running from a completely different 5V power supply, sharing only the ground with the 12V supply.)
So I went on to check the new power supply and found what is seen on the attached image. I forgot to set my 10X probe correctly, which should mean 500mV spikes that are most likely causing my trouble.
The question is: how could I get rid off these? I know this is very broad topic, but I am hoping in some practical advice. Right now I believe a simple inductor should do the lowpass filtering job, but what size? Is it correct at all?
Thanks.
Thanks.
