R7. Why would you place 8.2k in series with the ground for all the circuits?
R1, Why would you place 820 ohms in series with the power supply for the 555 chip (and everything else on the board)?
Why are three resistor hanging off the side with no job to do?
D1. If you're going to cheap out on 7 cent diodes, you have to double the filter capacitor size from (calculated) 150 uf to 300+uf. Ps, using half as many rectifiers doesn't reduce the DC voltage, that only makes the ripple voltage double.
Meanwhile, that 150 uf was calculated only for the receiver. This will need more capacitance to supply the 555 oscillator and the IR emitter. Are you locked in to the NE555? That will give me a solid number for amperage needs.
Meanwhile, the IR receiver has it's current limiter (R8) on the wrong end, there is no frequency limiting circuit between it and the 2N2222.
R6, R7, and R8 limit the current to the opto LED to 1.6 ma when it should be 20 ma. You can't run a triac gate off the base of the opto receiver transistor. You can't use an NPN transistor to control AC (wrong opto-isolator). You need a triac output opto to control a power triac. You can run a power triac gate with DC, but that would mean making a second DC supply with the second transformer winding or forfeiting the isolation feature of the opto-isolator. You have the fuse in the neutral line. C6 and C7 are supposed to be snuggled up against the 555 chip. And a partridge in a pear tree.
This looks like you're trying to make the connectors for the outside world nice and neat, at the expense of everything else looking like a bowl of spaghetti, and the spaghetti is wired wrong in so many ways.
I'm going to combine the transmitter and receiver circuits for you in a new drawing.
