What do you think the logic should be, since I know nothing, what does it look like and what would be more robust. Op-Amps and 555's with motor driver chips? I was thinking if you tie the auger circuit with a Vacuum to clear the burn area before the auger replenish's chamber. It would just suck up the ashes and deposit them in a small barrel, like a shop Vac system.Maybe that's the whole point.
Personally, I'm a really awful cook. Not because I can't learn, because I don't care. I prefer my salad without dressing and my cheeseburger without cheese. If these guys want to make a full blown engineering challenge out of it, I'll tell them what I know about air movement and temperature differences. It sure makes more sense (to me) than some other Threads, like using the wrong motor, then trying to get the denizens of AAC to engineer a way to stop it from humming.![]()
kv
