SMD LEDs 1206 and 0603
john2k
Joined Nov 14, 2019
219
Is there a model of SMD LEDs that are in between the 1206 and 0603 in terms of size? I need something closer to the size of 1206 but ideally a very little bit smaller. I might be able to actually fit the 1206. But for perfect fitment ideally if it's a tad bit shorter in width it will be perfect. The 0603's are too small
ErnieM
Joined Apr 24, 2011
8,415
Here is a link to about 4,000 surface mount LEDs that DigiKey lists as "in stock" : LINK
While overwhelming at first glance the selector filters can narrow down your choices, or as is gives you a view to all the different ways you can get a surface mount LED.
