smd identification
22,082
Maybe, but an LVC1G14 does not have two inputs. It only has 1 input, so I would keep searching. It is true that pin 1 is a no connect for that package so it is still possible, just unusual for the layout person to do that.
peterdeco
Joined Oct 8, 2019
484
I found 2 matches for V44.
V44
IXD2110C441MR
IXYS
SOT-25
DC/DC voltage converter IC
PFM step-up, 100kHz, 4.4V±2.5%, 400mA, +CE
V44
KIC73A44M2
Korea Electronics
TSM
Voltage detector IC
4.4V±1%, -Reset PPO, Td=240ms
34,814
I have doubts about the drawing supplied.
If the output is generated from PB6 from an STM32F103 why would they need to buffer or invert the logic signal?
If the purpose is to drive the emitter in an opto-isolator, why the need for the 180Ω resistor to GND?
The emitter of NEC9587 forward voltage is 1.65V typical, 1.8V max. Hence it could be have been driven directly by the STM32F103.
The 390Ω resistor serves no purpose but to waste power.
There are many SN74LVC1Gxx gates that match that pinout, for example, SN74LVC1G00.
Vcc on pin-5 would need +V supply.
euvasile
Joined Feb 15, 2018
11
the scheme is correct
euvasile
Joined Feb 15, 2018
11
Go back and read post #4.
:confused:
look at the picture
34,814
Your diagram shows 390 ohm resistor between Vcc and GND. That just wastes power.
The photo shows 390 ohm resistor between Vcc and NEC9587 pin-3.
34,814
STM32F103 is powered at 3.3V.
The cathode of the opto-isolator emitter is pinned at 1.9V.
All of this is totally unnecessary as far as I can see.
Kjeldgaard
Joined Apr 7, 2016
476
Now the circuit is starting to look a little more "sensible".
The voltage divider on the cathode of the optocoupler allows you to switch off the LED a little faster with a negative voltage.
