We're not mad. We simply can't help you, because you won't specify what your input(s) are, and what you expect (or want) to see on the outputs.how come you guys are. i am trying to design a circuit
Define what is "high voltage" to you.using resistors capacitors and op amps with high voltage.
If you would properly explain what your input signal(s) might be, we may be able to offer suggestions as to how to connect it up.is 44 v the highest voltage possible with op amps?![]()
Well, can you make an attempt at telling us what you want to see? Input voltage or current scaled up or down, or maybe inverted? We don't know.output is unknown.
Input and feedback are normally resistive, at least in part. Draw a schematic.input is resistors and capacitors with high voltage op amps.
You really have to give us more to go on.any advice is always welcome.
We don't know what your input(s) are.
We don't know what you need for an output or outputs.
We don't know why you keep asking for higher voltage, single-supply components, and then won't even attempt to tell us what you're trying to do.
Until you explain what you are trying to do, we really cannot help you.
