dcbingaman
Joined Jun 30, 2021
1,065
Ok.
I got much better performance when I slowed it down by changing the capacitor from 0.1uF to 10uF. It appears the op-amp cannot keep up, so slowing it down helps a lot. Also the second circuit I showed will work better than the first. But even in the second circuit use a 10uF. It does not work well unless the overall frequency is fairly low.
StijnC
Joined Oct 23, 2021
22
Hi I just built the one with the diodes and it seems to work, but the output should for example always be -14V (LOW) to 14V (HIGH). with this the circuit you sent, the average voltage is always zero, when the PWM is 100% for example its now at 0V and should be at 14V. Do you maybe have a solution for that?
Thanks in advance.
dcbingaman
Joined Jun 30, 2021
1,065
Thanks in advance.
Do you have R6 and C2 going to the negative supply rail? The first one I sent out did not do that, but it is important. Did you change the capacitor to 10uF?
dcbingaman
Joined Jun 30, 2021
1,065
Thanks in advance.
Are you using a 10uF capacitor?
dcbingaman
Joined Jun 30, 2021
1,065
Thanks in advance.
Are you sure the negative power input to the op amp is going to the negative 15V supply? A common mistake is have the negative power rail go to ground. I am just asking because I cannot see the breadboard circuit.
StijnC
Joined Oct 23, 2021
22
Okay I found the problem, I'm using a super cheap DSO138 oscilloscope and the button to switch from AC to DC coupling was stuck on AC. Now it shows the correct signal. Thanks a lot!
StijnC
Joined Oct 23, 2021
22
Could you maybe provide a small explanation why this works because I don't get the whole circuit, I also tried using a diode to put the signal on the schmit trigger but that only worked for small changes in duty cycle.
thanks in advance
StijnC
Joined Oct 23, 2021
22
ok, sorry about that, here is one possible solution replace R1 and R2 with a potentiometer wiper going to positive input. Replace R3 with a rheostat. The frequency and duty cycle can be set but it is not a linear relationship.
I also want to understand this so could you draw it with potentiometers so I can maybe see the mistake I made.
Thanks in advance
StijnC
Joined Oct 23, 2021
22
I edited my schematic a bit and now I have full range of the duty cycle circuit but the frequency changes with it, what is the cause and solution to that?20211024_120038.jpg
StijnC
Joined Oct 23, 2021
22
I also got this circuit to work now, but it has the same problem as mine, at high and low % duty cycle, the frequency changes with the duty cycle.
Ian0
Joined Aug 7, 2020
13,311
That will always be a problem because the time period varies with the reciprocal of resistance. When you have a potentiometer to set the duty cycle the time period will be
t\propto \frac {1}{R}+\frac{1}{R_{pot}-R}
where R is the setting of the potentiometer, and t is not constant as R varies
The only way to achieve independent adjustment of mark-space ratio and frequency is by using a triangle-wave oscillator and a comparator.
Alec_t
Joined Sep 17, 2013
15,163
Try your latest circuit (post #34), but without the diode, the 10k resistor and the 30k resistor. If you use the LM358, rather than the poor old 741 op-amp, connect the unused op-amp inverting and non-inverting inputs (not outputs) to ground to avoid noise pick-up.
Hint: If you get into the habit of giving each schematic component a reference designator (e.g. R1, C2 etc), it makes it easier to discuss circuits.
dcbingaman
Joined Jun 30, 2021
1,065
Thanks in advance
Here is the original circuit drawn with potentiometers. I will try to provide a circuit description for both a little later today.
