Single BJT IRF820 Driver, MOSFET not switching on fully
sghioto
Joined Dec 31, 2017
8,737
Should be 12 volts.
Check the resistor values of R1, R3 and R5.
If OK remove the transistor or disconnect the collector and measure the gate voltage which should be appx 12volts.
If not then the mosfet is defective.
coolyyz321
Joined Mar 17, 2017
90
I do have a D44VH10 NPN transistor that I could try to work into the circuit to toggle the IN-3 tube if the voltage rating is high enough. It came from my attempt at making my own HV supply for the nixie tubes, turned out it was too inefficient under load.
Ian0
Joined Aug 7, 2020
13,227
That DV44VH10 is rated at 100 volts max.
The schematic shows a 180 volt supply.
Driving a Nixie tube does not require a device rated as high as the supply, because there is a breakover voltage for the tube. You can drive Nixie tubes with TI's TPIC6B595.
coolyyz321
Joined Mar 17, 2017
90
That can work too, I ended up using 4 of KD155 Nixie tube BDC and 2 74HC595 to drive the 4 IN-14.
this switch was meant for an IN-3 colon as it’s only only thing thats left to be controlled.
Ian0
Joined Aug 7, 2020
13,227
Your processor output will have enough current to drive a nixie tube. Have you considered driving it common base? Use a high voltage small signal transistor. Base to 5V or 3.3V. Current limiting resistor between emitter and gate output.
coolyyz321
Joined Mar 17, 2017
90
I’ve never considered that. I just assumed that a MOSFET would be the best option for switching since there was high voltage present. I did put in an order for more MOSFETS so I’ll likely keep with that, especially since the PCB I made for the clock uses a circuit like the one listed.
