Single BJT IRF820 Driver, MOSFET not switching on fully
coolyyz321
Joined Mar 17, 2017
90
Hello, I am making a simple BJT and MOSFET switch to control the state of a IN-3 nixie tube with a microcontroller. Currently, I have the simulation in LTSpice running, although with my IRF820, the 2N3904 and it's current circuitry can't seem to switch on the MOSFET fully. Even with 11.7 volts going to the gate there are still some issues arising. What could I adjust to get the MOSFET to switch on fully?
I can attach my LTSpice files, https://drive.google.com/drive/folders/1h7pwr3ey3wk0qwx6KgAaaUyo-0ome40x?usp=sharing
38,934
Please label the node you are plotting with a Net Name, so we know what we are looking at, and then plot the gate and drain voltages of the M1.
V(n003) tells us nothing about what's being plotted.
Where did you get that MOSFET model?
coolyyz321
Joined Mar 17, 2017
90
The library .MODEL came from a manual input since Vishay does not have the .LIB file on their website anymore.
38,934
Input from where to where?
There appears to be a problem with that model.
The sim with a different MOSFET works fine (below):
(Note that by going to Plot Settings and selecting Add Plot Pane, you can simultaneously plot as many different nodes as you want).
coolyyz321
Joined Mar 17, 2017
90
I made a separate .lib file that contains the .model code.
In real life with these same components I am still having this issue with the MOSFET not being able to switch on or off. By this point do you feel that I should just switch to another MOSFET from the LTSpice simulation that worked?
38,934
I see no reason for that.
The IRF820 should switch just as well as the MOSFET in my sim.
I would double check your wiring, especially the MOSFET pinout (below):
But I did find the problem with your IRF820 model.
The RDS (shunt drain-source resistance when off) has a value of 3, whereas it should have a very high value such as 3E6.
My sim below with that value for the model included as a SPICE Directive:
coolyyz321
Joined Mar 17, 2017
90
Thank you for seeing the issue with the model file, I will update my .model accordingly.
As far as the physical circuit goes, once I get back from work I will make some measurements and test my MOSFET to narrow down what the issue could be. Everything is wired up correctly so it has to be a faulty component.
38,934
Sorry, I just noticed another problem with that model.
It's drain voltage is only going to about 13V instead 180V when off.
I haven't been able to determine what model parameter is causing that anomaly.
coolyyz321
Joined Mar 17, 2017
90
Thank you for helping out! This forum has always been a big help
coolyyz321
Joined Mar 17, 2017
90
MOSFET Test:
Drain-Source Diode Test: good, forward 0.6V backwards open
Gate Voltage: 3 volts
Now it seems like the BJT is the issue here. Could it be because the Arduino Pro Micro can’t supply enough current to the BJT?
coolyyz321
Joined Mar 17, 2017
90
I’ll try to take my microcontroller out of the pcb to manually apply the 5V and 0 volts to the BJT. Just to rule that possibility out
sghioto
Joined Dec 31, 2017
8,762
The gate voltage should be appx 12 volts when the transistor is OFF or zero output from the micro.
Are you trying to measure the gate voltage while it's being pulsed?
coolyyz321
Joined Mar 17, 2017
90
It’s being measured at pulses that are multiple seconds long. So like on for 4 seconds off for 4 seconds.
