Simple voltage follower - not working
Status
Not open for further replies.
bstdms
Joined Jun 14, 2023
22
Thank you for your time in advance.
I tried to simulate the action of a silicon photomultiplier(SiPM) using a second-order RC circuit and it worked well. The output voltage is named sipm and is shown as the red curve in the plot pane.
Then I wanted to connect this output to a voltage follower using the component UniversalOpAmp2 provided by LTSpice. The output Vo is supported to be the same as sipm, however, I got the green curve, which seemed to be shaped by a filter. May I ask why I got the curve and which part did I do wrong?
Many thanks.
Sho
wayneh
Joined Sep 9, 2010
18,184
Without investigating details and purely speculating, could it be that the op-amp slew rate is too slow for this? Try slowing down the sipm curve and see whether the op-amp does a better job of following.
38,952
Op amps have a limited frequency response, which is likely the cause of what you are seeing.
It's determined by the slew-rate and gain-bandwidth value of the op amp, which is 10MHz for that model.
You would need a much high gain-bandwidth to accurately reproduce that fast signal.
How much accuracy do you need?
WBahn
Joined Mar 31, 2012
33,374
Many thanks.
Sho
If you look at the initial rise of the opamp output, it goes up 12 mV in 10 ns. That's an average of 1.2 V/µs. The true slope is a bit higher than that, but those numbers are pretty typical slew rate limits for general purpose opamps. To track that signal, you are going to need an opamp with a minimum slew rate better than 100 V/µs and you might need one considerably faster than that.
WBahn
Joined Mar 31, 2012
33,374
I see it going up 54mV in an isstant, way under 1 nsec. It is too steep to actually read the time axis.
You are looking at the wrong signal. The opamp output is the green signal. It goes from 0 V to about 12 mV in about 10 ns.
The initial slope of the opamp output is perhaps 2x or 3x that average.
Status
