Hello all,
This is my first post on this forum. I recently started out with electronics, and after having bought a breadboard and some components, I started experimenting.
I built a simple circuit that I hoped would have worked. Basically, I'm trying to light a LED through a couple transistors. Using MSPaint as a schematic editor eek: ), here's what it looks like:
My logic here is this: the two resistors that you see act as a voltage drop. The bases of the transistors, after all, don't require 9V. At the same time, these resistors should lower the amount of current that flows through the LED so that I don't burn it. Since the bases of the transistors are always connected to the power supply, they should allow current to flow through them and light the LED.
However, nothing happens. The LED does not light.
Frankly, I'm not very experienced with a multimeter, so I don't know what to test and where.
Can anyone explain why nothing is happening?
