Hi all,
currently we are learning how to analyze and understand the working of electronic schema's. I got scheme " simple transistor tester circuit" (as an attachment in this post) which i have hard to figure it out how it works. I can identify and explain some parts of the scheme but the greater picture battles my mind.
If both transistor works (first one "npn" and second one pnp") the LED should flash (alternate between on and off).
- I believe that both transistors should be conducting before the LED goes on; Since the PNP transistor needs to get current out of the base the NPN transistor must be turned on, otherwise the base current from the PNP can't find his way to ground, correct ?
- I don't understand what the capacitator is doing at the bottom; The only thing i can think of is that the - plate of the ELCO charges up to 0.7 V trough the resistor of 330K and then the npn transistor switches on and the + plate of Elco = voltage emitter of the pnp = 3 - 2 (LED) = 1V
- the values of the resistors, especially the 330k is a mystery to me.
Thanks for the help
Thanks for the help
