Setting an Inverting Schmitt Trigger (op amp)
clark.donaldson
Joined Aug 19, 2019
30
Hello -
I have a waveform that goes from -10v to 10v. When it reaches 10v, I would like the Schmitt Trigger to output -10v. When the waveform reaches -10v, I would like the Schmitt Trigger to output 10v.
I believe the attached schematic is the standard circuit for doing this. But I am having trouble understanding how. It seems that Schmitt Triggers seem to be "tripped" at the ground voltage, instead of near either rail.
Is there a better op-amp or comparator circuit for this job?
KeithWalker
Joined Jul 10, 2017
3,604
Hello -
You need to add hysteresis to trigger at + and - 10v rather than at one set voltage.
ericgibbs
Joined Jan 29, 2010
21,439
hi clark,
What are the rise and fall rates of the +/-10V inputs.. ie: slow or square wave.?
What are the supply voltages to the OPA.?
E
clark.donaldson
Joined Aug 19, 2019
30
E
The rise and fall rates are variable. Ideally between 0.01 and 100 cps.
The supply voltage is +/-15v.
Can you help me understand how to do that?
ericgibbs
Joined Jan 29, 2010
21,439
hi clark,
Are you saying Ideally between 0.01 and 100 cps, does this mean sinusoidal.?
We need to know the shape of the input waveforms.
E
KeithWalker
Joined Jul 10, 2017
3,604
Here is a simplified explanation for you. Look at the circuit below:
When the input is at 0 volts, the comparator has two stable states.
If the output is at +15 volts, the reference on the + input will be +10 volts and it will remain that way until the - input exceeds +10 volts. Then the voltage on the output will become -15 volts. The reference voltage on the + input will change to -10 volts and it will be stable until the - input is lower than -10 volts.
This is a simplified explanation because the output will not switch between +/- supply voltage, but to something a little less. You will have to change
the value of R3 to suit the characteristics of the comparator you are using.
38,502
Here's a modified window comparator circuit using an LM339 or 393, that I think does what you want.
The LTspice simulation shows that when the input is below -10V the output is -10V, when above +10V it's +10V, and it's 0V otherwise.
It uses resistive dividers from the ±15V supplies to generate the trip point and the output voltage levels, so those levels will vary with any change in the 15V supply voltages.
The feedback to the (+) inputs provides about 50mV of hysteresis to minimize any oscillations at the trip point.
If you want a lower output impedance than the resistors provide (13.3kΩ max), you could add a non-inverting buffer op amp.
clark.donaldson
Joined Aug 19, 2019
30
Hi all -
I tested the simple Schmitt trigger circuit first, since it was quick to mock up. I haven't put it through all the paces yet, but it seems to work fine. Is there any reason that a window comparator circuit would be necessary instead?
Also, could you give me the equation for the threshold math? If it's (R2/R1+R2) * V - I'm not sure how it produces 10v.
38,502
My understanding is, you want two input threshold levels with three different output voltages.
If you can do that with your circuit, then go for it. :rolleyes:
Just plug in the numbers.
That's 10k / (5k+10k) * 15v = 10 / 15 * 15 = 10V.
Why didn't the math work for you?
KeithWalker
Joined Jul 10, 2017
3,604
Oh no, I only wanted two output voltages. When the voltage goes above 10v, I want -10v output, when it goes below -10v, I wanted 10v outputted.
The Schmitt circuit above used all 10k resistors.
When the output of the comparator is high, R3 is in parallel with R1 and when the output is low, R3 is in parallel with R2.
To get a hysteresis of +/- 10 volts, R3 = 2.5 Kohms.
