Brightness setting on your television ?
Externet
Joined Nov 29, 2005
2,678
Hi.
Is your TV brightness set to maximum ? Or you have no idea of the setting ? Would you like to have it brighter ?
So far found a clue on failure of backlights. All asked/checked so far have it set at full blast and would set it brighter if could. :eek: And it is also a default factory setting.
KeithWalker
Joined Jul 10, 2017
3,620
Hi.
No! The first thing I do when setting up a new TV or computer monitor is adjust the contrast and brightness for comfortable viewing.
cmartinez
Joined Jan 17, 2007
8,862
I usually set both brightness and contrast at 30% for visual comfort. But even that sometimes proves to be too bright for me. The trick is to try and make the screen look like a piece of paper under a lamp would look like. For instance, both brightness and contrast are currently set at 23% on my Gigabyte 3440x1440 monitor.
