Setting a timed trigger delay for a noisy signal
RichW
Joined Nov 8, 2019
40
I have a noisy signal, and would like the oscilloscope to capture the waveform at a certain time, rather than above a certain voltage threshold.
So, I am trying to trigger the oscilloscope with the function generator. But Trigger Setup Delay (please see image below) does not change the capture on the oscilloscope. I'm confused how to trigger the oscilloscope, should I be using the generator or the oscilloscope?
Thanks for any guidance.
38,757
What determines when the delay starts?
A delay has to be referenced to some point in time, which would be some point on the noisy signal.
RichW
Joined Nov 8, 2019
40
Ahh, I see. I went back and tried again. It seems that the way to do this is using sync, rather than the trigger function of the generator. Not sure why, but it works! Many thanks for the reply crutschow.
edit didn't work, see below
RichW
Joined Nov 8, 2019
40
Sorry for the long delay in reply. I think I kind of understand what was happening.
So, in burst / pulse mode the function generator emits counter like signal with the outgoing pulse. This is on even when the output is turned off. Therefore the function generator was triggering the oscilloscope even before I turned on the pulse output.
I solved the problem by triggering from the output signal directly, rather than the internal counter trigger thing. I basically need to capture at the point of outgoing signal in a very small time frame, not only to capture signals but also so I can minimise the viewing oscilloscope window (for increased sampling rate).
If that makes any sense?
