Yes, before I do anything I will check the voltage. On my generator at home, it seems to run at 2/3 speed. Frequency is 40 vs 60 and voltage is 145 vs 240. I also need to check that the generator energizes the wires all the way to the transfer switch.You should check for the presence of the presumed 60V. I suspect this is a bad assumption and the generator actually doesn't output any voltage until full speed is reached.
