Searching Node in List
Kittu20
Joined Oct 12, 2022
511
I have written code for linked list. I want to make a function that can search any specific node in list
C:
//Linked list code
#include<stdio.h>
#include<stdlib.h>
//structure for node in list
struct node
    int data;                              // first member of node in list
    struct node *next;                     // second member of node in list
// Add node to front of List
void insert ( struct node **current, int value)
    struct node *temp = malloc( sizeof( struct node));
        if ( temp != NULL )               // Memory allocated successfully
            temp -> data = value;         // assign value to first member of node
            temp -> next = *current;      // this member point to previous node in list
            *current = temp;              // temporary node becomes current node in list
int main()
  struct node *current = NULL;            // empty list
  insert(&current, 1);                    // node 1 hold value 1 in list
  printf("%d \n", current-> data);
  insert(&current, 2);                    // node 2 hold value 2 in list
  insert(&current, 3);                    // node 3 hold value 3 in list
   return 0;
Code:
N3 -> N2 ->N1-> Null;
@WBahn
How to make a function to find node 1 in list ?
WBahn
Joined Mar 31, 2012
33,116
What do you mean by "node 1"? That usually refers to the first node in the list (or sometimes the second, if counting starts with zero). Do you mean search for the node whose data is equal to 1?
By they way, do you see the use of double pointers here? Does that use make sense?
Are you interested in seeing a cleaner way to implement your linked list (it's the same basic structure, just wrapped differently to aid abstraction).
Kittu20
Joined Oct 12, 2022
511
"node 1" Means first node in list. Yes I want to search for node whose data is equal to 1
Double pointer store address of first pointer.
I wanted to update the value of the variable "current" through the function so I passed the address of the variable "current" to the function
Yes of course. I think my one drawback is that I didn't use typedef to define structure
WBahn
Joined Mar 31, 2012
33,116
I think you confusing a couple of things.
The notion of which node is first in a list has no connection to which node what defined first, which is what you appear to be assuming.
Your function inserts a new node at the front of the list. THAT node BECOMES the first node in the list.
It's the same as if I have a list of items with each item written on an index card. When I give you the cards, you only know the order that they are in at that moment, you have no idea what order I wrote them in.
So your "current" pointer in main is always (or better always) point to the first node in the list. In essence, whatever node that current points to is, by definition, the first node in the list.
The node whose data is equal to 1 is actually the LAST node in your list, because you inserted the other two nodes in front of it.
Typedefs definitely help for readability.
I'm working on some stuff right now that is going to take up most of my time for the next day or two, so I may not get back to fleshing this out for a while.
Kittu20
Joined Oct 12, 2022
511
Thanks for clarifying my mistakes. I am stuck with following function. I don't know how to find last node in function
C:
void search ( struct node **current, int value)
    struct node *Temp = *current;    // Temp hold memory location of first node in list
   // here need code to find last node
WBahn
Joined Mar 31, 2012
33,116
C:
What is this function going to do? It's a void function, so it can't return anything. If it changes the value of current, then whoever called is at risk of losing touch with the rest of the list.
But, leaving that aside, what do you know about the last node in a list that makes it different from all of the other nodes in that list?
Kittu20
Joined Oct 12, 2022
511
I learned how to add a node to a list. now i want to learn how to remove node from list. so before i need to learn how to find the any node in the list
But, leaving that aside, what do you know about the last node in a list and makes it different from all of the other nodes in that list?
The second member of the first node points to the second node in list.
The second member of the second node points to the third node in list.
The second member of the third node points to the NULL value.
djsfantasi
Joined Apr 11, 2010
9,237
If you read what YOU wrote, I think you have answered your own question. The pointer in the last node in your list is NULL. Unless your definition of the last node is different…?
Kittu20
Joined Oct 12, 2022
511
Are you referring to the definition of the last node given in post number #7? please correct it as i don't see anything wrong with it
Temp in search function hold the memory address of the first node in a list then how to set it to hold the memory address of the second node in the list.
WBahn
Joined Mar 31, 2012
33,116
And so what is different about the second member of the last node in the list, relative to every other node in the list, that makes it real easy to see if the current node happens to be the last node in the list?
WBahn
Joined Mar 31, 2012
33,116
It Temp points to the some node in the list, then isn't Temp->next the address of the next node in the list?
Kittu20
Joined Oct 12, 2022
511
Temp = * current;
Temp stores the address of the first node
Temp = Temp->next;
Temp should stores the address of the second node.
how to set Temp so it point to the last node in list?
djsfantasi
Joined Apr 11, 2010
9,237
Temp = * current;
Temp = Temp->next;
You have to go through the list node by node until you find the last node (when next=NUL). Then the last address is the address of the last node.
WBahn
Joined Mar 31, 2012
33,116
Temp = * current;
Temp = Temp->next;
Let's say that the list has 414 nodes. You could walk down the list doing the following:
Temp = * current; // Node #1
Temp = Temp->next; // Node #2
Temp = Temp->next; // Node #3
Temp = Temp->next; // Node #4
Temp = Temp->next; // Node #412
Temp = Temp->next; // Node #413
Temp = Temp->next; // Node #414
Temp = Temp->next; // Node #415 (which doesn't exist)
Temp = Temp->next; // Node #416 (which doesn't exist)
What check could you perform before each of these assignments to determine if you want to do the assignment or not?
Could you wrap all of this up into a simple (a very simple) loop?
Kittu20
Joined Oct 12, 2022
511
Yes, now I can do
C:
//Linked list code
#include<stdio.h>
#include<stdlib.h>
struct node
void List_Data ( struct node **current)
    while ( Temp != NULL)                // check List is not empty
        printf("%d ", Temp-> data);      // print data value of node
        Temp = Temp-> next;              // Temp point to next node in list
int main()
  // Display List data
  List_Data(&current);
   return 0;
Program Output
Code:
3 2 1
Kittu20
Joined Oct 12, 2022
511
I am struggling to delete specific node in my code. I want to remove second node from list.
I am looking help in delete function.
C:
//Linked list code
#include<stdio.h>
#include<stdlib.h>
struct node
void delete ( struct node **current, int value)
int main()
  insert(&current, 4);
  delete(&current, 3);                     // Remove second node from list
   return 0;
WBahn
Joined Mar 31, 2012
33,116
I find that drawing a picture really helps. Use a circle to represent a node, an arrow pointing down to represent the data, and an arrow leaving the right side to represent the next pointer. Draw a picture of your at least three nodes in a list and then draw what you want it to look like after you delete the center one. Now make that happen. Then go back and do the same for the special cases of wanting to delete the first item in the list and then the last item in the list. Sometimes your approach for working with an interior node works fine on one end or the other, but frequently you have to treat them a bit differently.
Kittu20
Joined Oct 12, 2022
511
I don't know the rules how to make diagram for linked list but I tried to make one as you said. If there is anything to be changed in this, I will gladly take your advice.
In the right hand diagram I have made three nodes and in the left hand diagram I am removing the middle node
Kittu20
Joined Oct 12, 2022
511
All you need to do is update the pointer to next in node 1 to point to node 3 and reclaim the memory used by node 2.
I do not understand how to do it in delete function post number #16.
i have a Temp pointer. I want to delete second node in code i have to find the node i want to delete.
