Searching for this part - T80-R toggle switch
Sonny Angell
Joined Jul 6, 2019
Salecom T80-R ON-ON-ON (datasheet and images attached)
I cant find this switch anywhere, I have contacted salecom they mentioned they have it but when I asked for a few switches I havent heard back.
The switch I need it here, but its sold out and I havent had a response to my emails
https://britishaudio.com/products/p...h-for-jsx-triple-xxx-ultra-series-guitar-amps
This switch is from my Peavey JSX guitar aamp (now discontinued) it toggles between three distortion settings.
I found something similar but the switch is too short and does not have the outer security cage.
Does anyone have any ideas of how I can find it or remedy this? Id rather not solder extension leads onto the legs.
-Sonny
ericgibbs
Joined Jan 29, 2010
21,601
Hi Ron,
The image on the link he posted shows only 3 pins, so assume OPDT switch. ie toggle centre Off.
He should be able to support the non thread section.?
E
panic mode
Joined Oct 10, 2011
5,306
NKK product such as M2024BB1UW01
M2024BB1G03
seem to be a direct cross but it too is without the V25 cage...
Sonny Angell
Joined Jul 6, 2019
Thank you for all your help so far!
Take a look side by side. I bought a switch I thought would work however it is too short and wont peek through the front panel.
On the right is the original switch (longer / taller)
On the left, its much shorter
I've had such a hard time trying to find a replacement. If it's tall enough, I would use a non-threaded version.
