Searching for a thru hole screw terminal.
nerdegutta
Joined Dec 15, 2009
2,689
Hi.
I'm searching for a part like this, with current rating up to 25-30amps. I know they are out there, but my search on Google, or in DigiKey, Farnell, Mouser has not given me any good answers.
Does anyone know where I can get one?
(This is a snip from Keystones datasheet)
I'm sure it's in my face, but I've search myself blind.
Ian0
Joined Aug 7, 2020
13,288
Thanks, but I believe both of these are the 8730, which is rated for 15amps, unless I'm missing something.
They are. You won’t get one with a higher rating, because of the amount of current that a single pin into the pcb can take.
if want a higher current rating it will need multiple pcb pins.
