Searching for Spec sheet
jstjules
Joined Feb 2, 2022
Hi everyone,
I am new in this forum.
I have a Notebook M/B to repair and I am searching for the spec on the part below.
It is identify:
15
97ARH E
See photo
Thank you
Moderators note : cropped image
jstjules
Joined Feb 2, 2022
Yes, but it is short on both side.
There are other on the M/B and it look like a diode. I am searching what kind of diode.
SamR
Joined Mar 19, 2019
5,488
Here are a couple of SMD marking code PDFs. There can be a lot of different components marked code 15. You will need to determine if the size/shape of the component matches and check the manufacturers PDF to insure it is the correct one. Knowing the type and size/shape of the component makes for a good start. Start by eliminating all that are NOT diodes and then those that are NOT the size/shape of the component. Then work with the rest looking for clues such as logos, date stamps, etc.
The SMD components marking codes database - Starting with '15' (yooneed.one)
Catalog.PDF (electroschematics.com)
