Hello everyone,
I'm new here so first thing is first.
My name is Marcel, I'm from the Netherlands. I own a company where I develop electronics on customer request.
Also a bit of production of pcba's with the use of a reflow oven, but only (very) small series.
Since I'm developping for all kind of customers I am not very specialised in a specific kind of electronics. So thats why I'm here.
I need to lay-out a design with alot of interfaces, including an ethernet interface and SDRAM (those are the "fastest").
Both interfaces are connected to a STM32F429ZIT, the SDRAM using the FMC (Flexible Memory Controller) at 90MHz, and the ethernet using the RMII interface (at ? MHz).
Now my question follows; is there anyone who has experience with these lay-outs and has got advise to keep in mind?
Like how important is the lenght match of those interfaces? And the impedances?
I'm using a 6 layer board with 4 signal layers, 1 ground layer and 1 power layer. On every layer (except power) there is a polygon pour connected to ground and stitched using via's.
I've attached an image where the SDRAM + current routing can be seen. The white square is the SDRAM (BGA). I've used 2 layers, top and bottom.
Thanks for your feedback!
