Have juist looked with magif.glass. Coal deposition seems to be coming from small bulging in C645 just near it. (Y amplifier)If there's soot on the pot you are advised to check it's resistance and wiper connection integrity...
Please give me a moment to find it on the schematicHave juist looked with magif.glass. Coal deposition seems to be coming from small bulging in C645 just near it. (Y amplifier)
i ll desolder R104 and check it. Will be tomorrow since I have to go shopping.Please check R104 and R98 out of circuit -- make sure R104's wiper maintains proper 'connection' to each 'end' throughout its travel...
@patpinHave desoldered R104: is 280 instead of 220 ohm; turning it degaged coal dust. Guess that's the one. Unfortunatly I dont have a spare. 'll have to order one. (Can be few weeks ...). I 'll keep U updated. Many thanks for yr fantastic help. Hypatia should be your protégé.
Good deal -- Please set it to ≈ 100Ω (Wiper to 'R98 end") and we'll continue trouble shooting!I have found a 220 ohm in another device and replaced the presumed bad one on the scope
I don't make much of that so long as the transformer is not overheating or (audibly) noisy...I rechecked supply voltages: test point 205/18 appears to be a little low (-12.66V (should be -13 V);
at R69 top -12.33 (expected -13V)
checked on trafo: 13V AC is not present either: it is 12.2VAC; (previous checks were 13V)(I checked with 2 DMM's)
the 100V point is only 93V (OK before)
110V is applied to the horizontal amplifier at point 156/29, whence it is connected to the horizontal driver (and other circuitry) via the decoupling network (R124 and C56) -- (Where are you seeing point 205/15 ???Dont understand that part of the diagram either. Fig 3; on top; Point 205/15 bringing 110V
The EMF drop across R124 will be slight for the following reasons:and after R124 (left of it) stil remaining 110V...no current through it?
110V is applied to the horizontal amplifier at point 156/29, when it is connected to the horizontal driver (and other circuitry) via the decoupling network (R124 and C56) -- (Where are you seeing point 205/15 ???)
1) The current demand of circuitry left of R124 (as per the schematic) is relatively modest.
2) Inasmuch as said demand is undular, C56 functions much as a filter (a.k.a. 'smoothing') capacitor..
Best regards
HP
Good...Hallo, R124 is 5.48K
Yes, please check the EMF across C56 (i.e. the 'left side' of R124 to the chassis) --- Please connect your indicator such that you may observe any EMF changes during the entire warm-up process until symptoms of 'full' malfunction appear)I cannot measure on C56 since I ll have to remove the whole time/div block. Are there other suspects we can check first.
Exteriorly C56 is in good shape( for what thats worth).
It was erraticly posted. Sorry
I'm using the schematic for your scope (D61A) -- anyway there is no real difference -- the drop will be negligible for reasons summarized in post #154Our diagrams are apparently slightly different. I see 110V at top Right and top left. In one of my first fig 3's the left side was cut off.
