Schematic for a 3 channel analog audio mixer
38,910
When I connect the DAC audio to the summing circuit, it slightly attenuates the bluetooth audio.
Yes, since the inputs act like a voltage divider, when more than one input is connected.
To avoid that change you can connect the unused inputs to ground.
There are audio connectors that can do that automatically (below):
You connect pin 3 to ground which then connects the pin 2 input to ground when not plugged in.
freeflyer
Joined Sep 9, 2016
169
I can’t do that because all inputs are used. The Bluetooth audio will play and so will the voice prompts from the DAC at set altitudes
38,910
Then as long as all inputs are connected, the gain won't change.
But for testing purposes, you can ground unused inputs to simulate they are connected (since the outputs of those devices are low impedance and essentially look like AC ground).
freeflyer
Joined Sep 9, 2016
169
After all these posts, you’re still using the incorrect circuit instead of the one shown in post #8?
Why does figure 3 in post #8 look different to figure 3 in the LM4871 datasheet (see below).
So if I use 20k resistors and 0.39uF capacitors for each of the 3 inputs with a feedback resistor of 20k it will work ?
The existing gain is 7 (as shown in post 12). If I use the resistor values in post #8 the gain will be 1, so surely it will be even quieter than it already is ?
Even if I directly connect an audio source (bluetooth left, right or DAC) directly to the input of the LM4871 eval board its very quiet. So how can decreasing the gain from 7 to 1 make it any louder ?
schmitt trigger
Joined Jul 12, 2010
2,275
This is post 8, modified to fit your requirements. Panic Mode outlined the changes. It should work although the gain may require adjustment.
IMG_1279.jpegNow this is post 3, with a biasing scheme that is shorting the audio signals.
ci139
Joined Jul 11, 2016
2,037
basically the stereo difference is at most cases orders of magnitude less than the mean audio level =
= you can weigh the L+R audio to be comparable to your "digital input"
(( . . . also at #29 [ #3 ]) the resistor is missing from the output of the TLV2372 (fixed to the supply median) to the summing point of the input sources ))
panic mode
Joined Oct 10, 2011
5,420
schmitt_trigger is right. virtual ground using buffer OpAmp is fine. but it also means that it will do what it designed to do - prevent changes at that point. basically it would also dampen (short circuit) the other three audio channels that you are trying to amplify.
38,910
The Fig. 3 circuit is Post #8 and Post #29 has the LM4871 input as a virtual ground summing point due to the negative feedback from Rf.
I see no problem with that.
It is not "shorting" the input signals, it is summing them as currents, as any typical inverting op amp summing circuit does.
freeflyer
Joined Sep 9, 2016
169
I do have that resistor fitted, it’s value is 100k
What I find strange is that if I connect any of the s single audio channels (Bluetooth L or R or DAC) directly to the input of the LM4871 eval board input (ie no series resistors or caps) the sound is still very quiet. And the gain of the LM4871 board is 7.
38,910
What is the output voltage of those signals?
What speaker are you using?
panic mode
Joined Oct 10, 2011
5,420
to avoid audio channels influencing each other, you may add buffer to each audio input before summing, as for measuring output across speaker, yes differential probe is ideal, or using two probes and let the scope do the math Ch1-Ch2... or just measure one channel at a time and post both screenshots. for audio signal use single tone like 1kHz
