FM Radio schematic
Homebrew1964
Joined Nov 22, 2024
289
I just built the FM radio circuit here and after a fashion i got it working, the problem is it is EXTREMELY quiet audio to the point i had to put the speaker on my ear to hear anything.
Has anybody built or have a known working circuit i can try that gives a reasonable output?
I have found some on a google search but i am aware that there is a lot of garbage posted online that just doesn't work, so if anyone has a known working circuit, that would be great.
I don't know if the low output of the circuit i built was down to the radio receiver section or the amplifier section.
Homebrew1964
Joined Nov 22, 2024
289
Output of the LM386 must be terminated with a proper R-C network , read the data sheet.
I checked the data sheet and i had the resistor and capacitor switched around with the resistor connected to pin 5 and then the capacitor going to ground, might this have been why the output was so quiet?
35,078
If two devices are connected in series and nothing else connected at the junction then it makes no difference which one comes first.
schmitt trigger
Joined Jul 12, 2010
2,196
I mentioned this only because the posted circuit doesn’t show the resistor in series with the capacitor.
But if you actually included it in your prototype, then it is fine.
Homebrew1964
Joined Nov 22, 2024
289
Yes i added it but like i said i had reversed the resistor and capacitor although Mr Chips said that doesn't matter, i also added a 0.1 uf across the supply rail directly on the supply pins of the IC and that stopped the oscillations i was getting on the output.
sarahMCML
Joined May 11, 2019
703
In the URL you reference, the author talks about placing C6 between the positive input and ground, which is pin 3, but shows it connected to pin 2. So yes, it's doing nothing as shown, and needs to be moved.
I have taken it apart to reuse the parts....sorry i don't have any pics of it.
"I just built the FM radio circuit" :cool: and the next day you've taken it apart after having issues. ;)
Glad to see you're rebuilding it for us. Some pictures of the new build please.
Documentation is the key here. Your physical build is the documentation we need to give good answers to the question. Only showing us a decades old schematic really doesn't' help.
Homebrew1964
Joined Nov 22, 2024
289
Just to tidy this thread up...........I rebuilt the radio circuit this time using a couple of RF transistors that i ordered specially for the job (BF494) instead of using BC547's and instead of the LM386 circuit in the original design, i added the one in the second schematic that i uploaded (i'll upload both here in this post) after correcting a couple of shorts on the stripboard where i hadn't made breaks the radio is loud....it's VERY loud.
I don't know if it was the change in transistors that did it or the slightly different arrangement with the LM386 but
thankyou to everyone who replied on this thread...i am very happy with the result.
Still no photo of the build.
