Help needed in 4 channel SSR Relay schematic
saqeb
Joined Nov 21, 2022
9
Hi friends,
I am a software engineer and there is a requirement to build a custom 4-channel relay PCB. I have designed a PCB but I am a bit confused about connecting SSR INPUT PINS (polarity). Can anyone of you help me? I will use this relay PCB for arduino compatible ARM I Just want to make sure before fabrication and SMT that nothing is wrong. Sorry if I fail to elaborate my problem clearly.
https://oshwlab.com/saqeb/relay-test
ronsimpson
Joined Oct 7, 2019
4,804
Please post an athematic.
Relay part number https://media.digikey.com/pdf/Data Sheets/Omron PDFs/G3MB.pdf
There are two filled areas on the PCB. Ground and supply?
The diode across the relay input is not needed with a SS relay.
The copper area "ground & supply" should be increased to the left to include the input connectors. Extend to the left almost to the edge of the PCB. The grounds in that area are week.
I don't know what voltage the relays are driving but I think power line voltages. The spacing is too small! Near the output connectors the copper is almost touching copper.
You need more space in these places.
ronsimpson
Joined Oct 7, 2019
4,804
I updated my comments above. You might have to refresh to see the changes.
I do not understand why the "MOV"? The output connector, MOV, relay and back to the connector, I do not understand. I think the MOV should be across the relay not in series with it.
35,138
Examine every trace and make sure that they flow nicely horizontally and vertically while being well spaced away from each other and other pads. Check to see if there is a different way of routing each trace. See if the trace can be routed on the bottom layer instead of the top layer.
I don't see any need for flood planes for this application.
PCB layout is called "artwork". Thus it should be your piece of art that you can stand back and pat yourself on the back for creating a beautiful piece of art.
It would help if you posted the schematic diagram.
saqeb
Joined Nov 21, 2022
9
Dear Ronsimpson.
I am really very thankful for your detailed reply. I will remove the diode between relays. Again I am thankful and best wishes for such an active community.
saqeb
Joined Nov 21, 2022
9
Thanks for your valuable comments.
ronsimpson
Joined Oct 7, 2019
4,804
There should be a capacitor from supply to ground on the board. I might use four 0.1uF capacitors.
You can never go wrong with too much ground.
Please post your next layout.
ronsimpson
Joined Oct 7, 2019
4,804
One option if to place a single capacitor from supply (blue) to ground (red) right of the input connectors and left of the small parts. Because you have good grounds a single capacitor will be fine. Normally I add a small capacitor near each transistor.
saqeb
Joined Nov 21, 2022
9
Hi Ronsimpson,
I am very thankful for your valuable comments and advice. I have redesigned and shared the schematic for your kind review. Thanks in advance.
https://easyeda.com/editor#id=|0167615896994ea48c8f0886852af08b
ronsimpson
Joined Oct 7, 2019
4,804
There needs to be a resistor with the "power LED".
Why D1,2,3,4? What is the supply voltage?
Looks good. Did you increase the spacing between traces at the output connectors?
panic mode
Joined Oct 10, 2011
5,226
very messed up and confusing thread....
1. why not post actual image of the schematic and PCB in the forum posts? having links and then changing linked content makes the thread unreadable.
2. schematics shows missing relay
3. schematics shows circuit using PNP transistor but mentioned BC547B is an NPN
4. why pass traces through SMD components? moving something slightly may completely remove need for any such 'crossing'
5. trace are passing way too close to other traces, vias and solder pads, specially in the AC section. is there a DRC in that EDA? why not setup design rules to ensure needed clearance?
6. what do you think is a reason that relay output contacts are spaces so much further apart? it is because for high voltage circuit you NEED big clearances...
so... do you know how to measure? how about keeping at least 4mm between two traces in AC section?
so ... how about something like this:
7. where are the component identifiers in the silkscreen? who can tell where the R1,R2 etc are?
8. what is the DIP4 product? an optocoupler? where is it in schematics?
saqeb
Joined Nov 21, 2022
9
The supply voltage is 5v, should I place a resistor for LED?
The input signal is 3.3v (Arduino like board) so I place diode (S8550-PNP). Load will be AC 22V 1A
I am sorry for incomplete information.
saqeb
Joined Nov 21, 2022
9
I am sorry, I will post actual image of schematic.
MaxHeadRoom
Joined Jul 18, 2013
30,805
Those boards appear almost identical to the Opto22 line, they are available all over the net, ebay etc.
I just got rid of boxes of them that I no longer had a use for.
You can get all kinds of I/O configurations, including those that work at logic level and 24vdc.
Both AC and DC Input/output. Various boards sizes to accommodate 4,8,16,24 modules. including relay as well as SS.
They come fused together with status LED.
If you do want to make up your own boards, Opto22 have the engineering specs.
panic mode
Joined Oct 10, 2011
5,226
Opto22 is a good example. if making own, check other designs (even if not solid state).
note wider traces for relay output, greater clearance between output tracks and cuts in board when distance is not sufficient
