I have an idea--tell me if you think it has merit.
The damage appears to be localized and above and/or just below the present keeled over water line. If this is true, could it be patched on site using suitable materials? I also believe that underwater work is also feasible--just a crude patch job that will be essentially water tight.
Attach perhaps 100 cables that are tied to bedrock and attempt to very slowly rotate the vessel to the point where the starboard gunwale is just above water--this could be done as they are off-loading the vast supply of fuel.
When the gunwale is above water, start pumping until the ship is essentially afloat, but perhaps still grounded--at the same time start scuttling everything on board that is water damaged and /or portable--this will vastly lighten the ship so its draft will be minimal.
At this point it may be towable if done with care...
If nothing else, it may get the ship to a drydock for easier salvage
