Sartorious Bench scale display issue - black vertical bars
Kevin Johnson QE
Joined Apr 29, 2021
Hi all,
My sartorius bench scale electronic display is displaying vertical black bars that is making it incredibly difficult to read the display
Precious weighing equipment that is accurate to 1000th of a gram, so can't be buying a new scale entirely
As you can see it is almost impossible to distinguish between a 6 and a 5 except for one pixel
Powder infiltration is strongly suspected
Will the rubber electronic contacts that connect the screen need cleaning? what's the best stuff, as IPA cleaner is still a little bit greasy
Thanks,
Kevin
Ya’akov
Joined Jan 27, 2019
10,370
99.9% IPA is the best you are going to get. There is nothing “greasy” about it, it is nearly anhydrous alcohol and will evaporate so close to completely that it makes no difference.
Kevin Johnson QE
Joined Apr 29, 2021
To clarify, the rubber electronic contacts refer to it’s elastomeric connectors, as I can only imagine contamination of them would be capable of creating such an error, where conduction zones control one pixel row? I will be cautious and see if it can be done with wiping with just a dry q-tip (gently twisting away as I go in order to not cause scratching) good inspection with jewellers loop, then if no positive results use a quality brand name IPA spray, applying it to q-tip in close proximity https://en.wikipedia.org/wiki/Elastomeric_connector
Ya’akov
Joined Jan 27, 2019
10,370
Most of us are very familiar with zebra connector. Sometimes, delamination rarher than contamination is the cause. if so, pressure will cure it.
