Converting legacy 450-Watt Storagework power modules for bench use?
tidip45736
Joined Mar 28, 2026
Hey everyone,
I recently stumbled upon a couple of older 450-Watt Storagework power supplies from a decommissioned server rack. They are built like absolute tanks compared to modern consumer-grade units, and the internal component quality is honestly impressive for their age. I’m considering converting one into a dedicated bench power supply for some of my more power-hungry electronics projects, but I’ve run into a bit of a wall regarding the control logic.
One specific point I’m struggling with is the proprietary interface connector these units use. Unlike a standard ATX power supply where the PS-ON and ground pins are fairly universal, these storage modules seem to have a much more complex handshake protocol or specific resistance requirements to actually "wake up" the main rails. I've spent the last couple of evenings with a multimeter trying to map out the standby rail and the trigger pins, but I’m hesitant to start jumping pins without a clearer understanding of the sense lines.
In my experience, these enterprise-grade units are incredibly efficient, but they are often designed to prioritize a massive 12V output for drive arrays while being relatively "stingy" with the 5V and 3.3V rails. I’m wondering if anyone here has successfully bypassed the logic on these 450-Watt modules or if I should be concerned about high ripple on the 12V line when it’s not under a significant load. I’d hate to fry a sensitive project because I underestimated the switching noise or the lack of a minimum load requirement for stability.
Has anyone here had much luck repurposing these specific types of "sled" power supplies, or is it generally safer to stick with a standard lab unit despite the lower current capacity?
28,279
IF you have access to that deecomsioned server rack then you are fortunate! It should be possible to discover which connections are used to switch on andswitch off, And which are the sense inputs for remote sensing. Otherwise it will be a bit of guessing. The supplies may also deliver other voltages besides +12 volts.
