Recently deciding to complete my 1987 project (!!) from the 1979 book “How to Build Your Own Self programming Robot” (by David L Heiserman) that I started whilst at college I would like to confirm a few possible circuit errors that I’ve noted.
From Schematic 11.2(attached);
Memory Address lines MA0 - MA3 pass through the 74LS367 buffer/driver (IC Z121) on the lower 4 (of 6) gates,whilst MA4 & 5 pass through on the upper 2 gates.
MA6 & MA7 pass through on the bottom 74LS367 (IC Z122), but the input-output pins 11/12 & 13/14 appear crossed.
The same error also appears on schematic 11-3 for the High-order memory bits MA14 and MA15. Scrutinizing even further it looks like the data lines MD4-MD7 (on Z1191) are also crossed as these connect to the Data-In pins of the RAM chips*. The same error being seen back on schematic 11-2 with MD0-MD3 on Z122.
My conclusion being that both IC’s Z1191 & Z122 input / output pins should have been drawn mirrored?
The corresponding circuit description from the book has been attached, along with the two relevant circuits.
(* The memory chips listed for the extended memory actually have separate Data-in and Data-out pins (and are 1 bit chips!) therefore I intend to update these to some standard type (maybe nonvolatile, like FRAM’s), but before commencing would like to rectify any errors on the circuit ‘as drawn before making my updates)
