Line follower robot without MCU
panic mode
Joined Oct 10, 2011
5,241
there are million ways to do that. simple solution is to use sensor that can detect line. if sensor sees the line, motor on that side need to slow down or stop. so two such circuits will continuously keep on adjusting speed of their motor while moving forward.
if the line is sufficiently wide, single sensor can be used. this will follow the edge:
