Ringing a buzzer when timing is over with a 555 monostable
calmachicha
Joined Jan 18, 2025
15
Hello everyone.
I'm new here and I've been looking at the forum to familiarize myself with the topics, which I will continue to do daily.
What brings me here? I've built a variable timer with a 555 that can be set to between 10 seconds and 10 minutes, approximately.
I want a buzzer to sound when the set time is up, which I did, but with a disadvantage. Since the buzzer is activated when the 555 output is low, it also sounds when the circuit is energized but the timing has not yet started. Is this possible without complicating the circuit too much?
I hope I've explained myself well.
Your answers will be welcome.
Thanks to everyone.
calmachicha
Joined Jan 18, 2025
15
Hi. Thanks for the reply.
I had thought about that, but I didn't know how to trigger it from the other circuit.
I have added your proposed circuit to the simulation, but unfortunately it doesn't work. The 555 output from the second circuit never goes positive. Unless I'm doing something wrong.
Regards
38,856
Below is the LTspice sim of my take on a two 555 circuit:
The relay coil current is the blue trace.
It resets the second 555 to stop the output.
calmachicha
Joined Jan 18, 2025
15
Tienes razón. Lo hice de todos modos porque me faltaban algunos artículos. Lo intentaré de nuevo mañana después de realizar la compra.
¡Muchas gracias!
calmachicha
Joined Jan 18, 2025
15
With some tinkering and a lot of magic I managed to make the buzzer sound in the simulator, but with the same problem that I mentioned in my first post.
The buzzer sounds when the output of the first 555 is low. And this is the original state of the circuit before pressing the start button of the timer, so the buzzer sounds without having activated the timer and stops, logically, when it starts.
I think, conceptually, that with these elements it is impossible to avoid this behavior, unless the start button activates a relay or another device that energizes the circuit simultaneously with the start of the timer.
I will try to deal with this.
Any opinion or suggestions are welcome.
Greetings.
calmachicha
Joined Jan 18, 2025
15
The tweak to the simulator was that I added a series resistor between OUT and the buzzer. It worked once. Never again. (?)
Afterwards, almost playing, I hit the STOP button while the timer was running. Then it beeped again.
I think the simulator is not working properly.
The issue that motivated me to post is the one I mentioned before. Whenever OUT is low, it will beep, whether the timer has been activated or not. I think your opinion is different and more well-founded. I am just an amateur with little knowledge.
sghioto
Joined Dec 31, 2017
8,756
MisterBill2 said:
"If it is a switch that triggers the timer, use a double pole switch with the other half opening the buzzer circuit when the timer is not triggered."
Variation of the above suggestion.
Sw1 is a DPDT toggle or locking type push button switch shown in the Reset position.
