RF Choke for low frequency
Toni Rodri
Joined Dec 3, 2023
49
Hey
I have a circuit that work with frequency range of 25KHz - 50KHz.
I have op-amp and another devices in the circuit that need to work with VDD and VDD/2 and in some cases I integrate directly into the circuit.
I want to use RF choke to supply DC to the circuit and to block the frequencies.
For this case I search inductor that greater then 1mH but my problem is that all the inductor that I find, there DCR is high.
I work with 3.3V Supply and my max Current is 0.7A so on the Inductor the voltage drop will be very high.
I look about common mode choke with this inductance but their DCR is low, the problem is that I don't have some experience with common mode choke.
My question is if I can use common mode choke like a RF choke? How I can connect it in my circuit.
and another question if there is another solution to replace the RF choke with something else.
Thank you very much
Toni Rodri
Joined Dec 3, 2023
49
How much attenuation does Your project require ?
I didn't understand the question. I have a reciever path.
I recieve some signal into op amp and then to adc.
my problem is with the rf choke with the supply voltage and to supply vdd/2 to work with the op amp with single-supply
Papabravo
Joined Feb 24, 2006
22,112
Do the math and it will be revealed to you that an impractical inductance will be required at those frequencies. Do you know what size antenna would be required to radiate any significant energy at those frequencies? You seem to be worried about trifles.
Toni Rodri
Joined Dec 3, 2023
49
I didn't need antenna
ronsimpson
Joined Oct 7, 2019
4,782
If I was trying to keep RF from getting into the op-amp I would do this.
Add a CLC filter to the supply.
Also add a cap from (-) to (out) of the amplifier to slow it down. It looks like an audio amplifier that does not need to work above 20khz.
The next circuit looks to be a RF power amplifier. Which is not much more than a transistor. Read the data sheet. Give us a part number.
Pyrex
Joined Feb 16, 2022
532
where the value of 1 mH come from?
