Review Request - LED and Switch Breakout
radi8
Joined Oct 18, 2024
24
I have been recently working on a board which just breaks out a few switches and LEDs for easy soldering to a Raspberry Pi. There isn't much of a circuit, but I would like guidance if I chose suitable resistors, etc. I have two LEDs - APT2012LZGCK (2mA @ 2.65Vf - with a 330Ω res.) and an APTD1608LSECK/J3-PF (2mA @ 1.8Vf - with a 750Ω res. respectively). Other than that, there isn't much else to the circuit besides two switches. Everything is broken out into SMD pads on the bottom. I would have chosen PTH pads, but I had ill luck with them last time. In the PCB layout, red is top layer, and blue is bottom layer.
Could I get a sanity check on this to make sure I'm not losing my mind? Thank you in advance.
