Reverse polarity protection - 24v to 5v - PMOS
Francois Coulloudon
Joined Aug 12, 2015
2
Hi everyone,
I've read several threads but couldn't find the answer I'm looking for.
I'm trying to protect my circuit the same way the attached schema works (using PMOS)
I've read this one:
http://www.electro-tech-online.com/...ion-of-input-power-with-low-voltage-drop.664/
and this one
from other threads
However I'm having a specific question regarding the voltage of my own circuit.
I want to support 10-26v as VIN (in fact 12v to 24v but with some margin).
I plan to use either UA78M05CDCYR or LM2937IMP-5.0/NOPB to go from 12v-24v to 5v.
My problem is that Vgs using a P-channel in this case can theoretically be at some point 0 - 26v (-26v) or 5v - 26v (-21v) and most of the Pchannel I find in the package I want are max VGS -20v.
1) Do you believe the case Vgs (-26v is possible?)
2) In the case I have 25v supply, we will be @ Vgs -20v, do you think it's a safe practice to stay close to max limit?
What do you recommend me to protect from inverse polarity?
Thanks in advance for your help!
Francois Coulloudon
Joined Aug 12, 2015
2
I believe with a Zener diode in parallel of Vgs and a resistor I'll be fine. Just need to check current is alright but by simulating with LTspice it sounds good...
I think I answered the question by myself...
Please let me know if I'm doing something wrong :)
Bernard
Joined Aug 7, 2008
5,784
If you can stand a diode V drop a single diode would provide reverse V protection, or with 2 D drops, a bridge rectifier does not care what the input polarity is.
38,600
Your P-FET is the wrong way round in the attached png file.
No, it's correct. The P-MOSFET drain is connected to the input voltage so that it can block the voltage when the drain goes negative from an incorrect connection.
A MOSFET conducts equally well in both directions so will turn on when either the drain or source is positive with respect to the gate.
Alec_t
Joined Sep 17, 2013
15,132
Oops. My bad. However, 5V on the gate won't allow on/off control of the MOSFET if the supply is 24V.
38,600
5V appears to be just a bias voltage to keep Vgs from exceeding its maximum of 20V.
24V will generate a Vgs of -19V which will turn it on, as desired.
0V will generate a Vgs of +5V which will turn it off, again as desired.
