Reverse Polarity: P FET or N FET?
brightnight1
Joined Jan 13, 2018
97
I have an application that I need to add reverse polarity protection on but it needs to be extremely efficient. My understanding is that a P FET or an N FET would be more efficient then a Schottky diode. How or why would I pick between using a P FETor an N FET as a protection diode? I’ve heard that N FETs are cheaper then P FETs, is that true and what other considerations should I think about when choosing between a F FET and an N FET? Thanks in advance.
38,584
You can use an N-MOSFET with the same simple circuit as a high-side P-MOSFET, but it must be connected in the common/return line.
This means the voltage source and the load must not have a common ground connection.
N-MOSFETs are indeed cheaper than P-MOSFETs for the same voltage and current rating.
brightnight1
Joined Jan 13, 2018
97
What kind of FET are you referring to? JFET, MOSFET, MESFET, ...?
MOSFET. Most likely for a 3.6V battery. From what I read those are likely the best solutions but certainly open to suggestions :) Thanks to everyone for all the comments and advice!
