Reverse of Shift Register?
Zane Finner
Joined Jan 29, 2018
30
Okay, so I've recently gained an interest in arduino shields. I find the add-ons quite attractive and useful. I stumbled upon a 64 button shield and even though the normal Rev3 has 13 i/o pins, you can have 64 buttons! Now, my question is; Can I make some sort of input extension? Are there other IC's for it? Is there code that allows you to have 2 specific pins be used for a button(for example, pin 6, 7, 8 could all be inputs while 9 10 and 11 outputs. If 6 --> 9, x happens, if 6 goes to 11, z happens, if 7 goes to 11, q happens)? Please let me know if I am not being clear. I have a problem with coherency and will not get upset.
Thank you
You are a kind community :)
shteii01
Joined Feb 19, 2010
4,644
all you need is ic that does serial communication. take computer keyboard, the old style that uses ps/2, it has 4 wires: power, common, rx, tx. since you are only going to receive buttons from keyboard, you only need power, common, tx. connect power to arduino board 5V, connect common to arduino board common, connect tx to software serial rx pin on arduino board. Use Software Serial program written for arduino to use any digital pin for serial communication.
The reason this works is because keyboard has its own microcontroller. When arduino board talks to keybard, it actually talks to keyboard microcontroller. So you have one smart device (microcontroller on arduino board) talking to another smart device (microcontroller inside the keyboard).
be80be
Joined Jul 5, 2008
2,395
You want read up on I/O EXPANDER WITH I2C INTERFACE IC
And CD4014B parallel-in/ serial-out 8-bit shift register
http://data:image/webp;base64,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 http://data:image/webp;base64,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
Zane Finner
Joined Jan 29, 2018
30
Thank you, that helps lots :)
