Reverse LDR
zorgloub
Joined Apr 19, 2016
18
Thanks Eric.
Well, I put Diac_st.lib in the LTSpiceXVII/LIB/SUB directory and DB3.asy in LTSpiceXVII/LIB/SYM and even in LTSpiceXVII/LIB/SYM/MISC but ... DB3 still doesn't appear in the F2 window !??
I'm at a loss :(((
ericgibbs
Joined Jan 29, 2010
21,552
hi z,
I have reloaded again, all OK.
Have been checking the web for any examples of problems with DB3.
Will ask @Bordodynov to advise, being tagged should alert him.
E
Just checked on a second PC, the DB3 is there in F2, puzzling.
ericgibbs
Joined Jan 29, 2010
21,552
hi z,
Just checked my other two PC's , the DB3 is in F2.??
I will investigate further, if I get a breakthrough will post.
E
Update:
These images show the location/path in my PC.
Can you post images showing the location/path in your PC.?
Alec_t
Joined Sep 17, 2013
15,152
By default LTspice looks for its files in your Documents path.
ericgibbs
Joined Jan 29, 2010
21,552
hi AB,
What is the reason the post #12 circuit does not work with that Diac.?
May I ask why the original DB3 sub model was modified.?
E
